Report Designer module
This section contains sample recipes related to the Report Designer module. For more details, please click on the links below to access their respective pages.
  1. How To Create A Report Template With 2 Level Sub Report
  2. How To Add Column With New Record
  3. How To Add RTF Content
  4. How To Calculate And Collect Sub-Report Values
  5. How To Calculate Correlation
  6. How To Customize Page Information
  7. How To Customize Parameter UI
  8. How To Dynamically Resize Image
  9. How To Format Data By Making Negative Values Bracketed
  10. How To Hide Duplicates
  11. How To Display Records In Horizontal Tiles
  12. How To Pass Parameter To Group Sort
  13. How To Print A Line At The End Of “Detail”
  14. How To Process Byte Array
  15. How To Read Binary Image
  16. How To Remove Column In Cube
  17. How To Render Dynamic Columns
  18. How To Repeat Header Using Script
  19. How To Return Value From Sub-Report
  20. How To Simulate Report Band
  21. How To Terminate Report Rendering
  22. How To Track Report Generation
  23. How To Underline Element With Logic
  24. How To Use Cube In Report
  25. How To Work On Charting
  26. How To Work On Data Cache
  27. How To Work On Date
  28. How To Work On Dynamic Column Report
  29. How To Work On Dynamic Labels (Language)
  30. How To Work On Font
  31. How To Work On JavaScript
  32. When No Data Is Found
  33. How To Control Orientation
  34. How To Change Rectangular Element To Oval
  35. How To Work On Renderer
  36. How To Work On Report Components
  37. How To Work On Section Handling
  38. How To Work On Style
  39. How To Work On Variable In Action
