In the report design, there is a field that may return a negative value. The goal is making every negative value bracketed instead of showing the negative sign, and the positive value will remain as it is.
For example if the value is –123, it will display (123) in the report.
// The 0 symbol shows a digit or 0 if no digit present
NumberFormat formatter = new DecimalFormat(“000000”);
String s = formatter.format(-1234.567); // -001235
// notice that the number was rounded up
// The # symbol shows a digit or nothing if no digit present
formatter = new DecimalFormat("##");
s = formatter.format(-1234.567); // -1235
s = formatter.format(0); // 0
formatter = new DecimalFormat("##00");
s = formatter.format(0); // 00
// The . symbol indicates the decimal point
formatter = new DecimalFormat(".00");
s = formatter.format(-.567); // -.57
formatter = new DecimalFormat(“0.00”);
s = formatter.format(-.567); // -0.57
formatter = new DecimalFormat("#.#");
s = formatter.format(-1234.567); // -1234.6
formatter = new DecimalFormat("#.######");
s = formatter.format(-1234.567); // -1234.567
formatter = new DecimalFormat(".######");
formatter = new DecimalFormat("#.000000");
s = formatter.format(-1234.567); // -1234.567000
// The , symbol is used to group numbers
formatter = new DecimalFormat("#,###,###");
s = formatter.format(-1234.567); // -1,235
s = formatter.format(-1234567.890); // -1,234,568
// The ; symbol is used to specify an alternate pattern for negative values
formatter = new DecimalFormat("#;(#)");
s = formatter.format(-1234.567); // (1235)
// The ’ symbol is used to quote literal symbols
formatter = new DecimalFormat("’#’#");
s = formatter.format(-1234.567); // -#1235
formatter = new DecimalFormat("‘abc’#");
s = formatter.format(-1234.567); // -abc1235
FormatingData.zip (4.1 KB)
