In v7 only Group Header can ‘Repeat Header’. In this sample we will demonstrate on how scripting can be used in report template to ‘Repeat Header’ on Data Grid and HBox Element.
- Consider the number of row a page can contain. (Example: 10 records in 1 page)
- In ‘Function Definitions’ declare the record count:Example:
var rowCnt = 0; - Insert a dummy Header which you want to repeat.
- In the data, this script will count the rows while rendering.Example:
HBox:On Render End -
rowCnt++; - In the dummy Header, Render If record count is 10, 20Example:
HBox:Render If -
rowCnt == 10 || rowCnt == 20; //this will indicate on which row the dummy Hbox header will appear. For this case it will appear on rows 11 and 21 respectively - In the dummy Header, set the visible to true when it is rendered.Example:
HBox:On Render Begin -
this.setVisible(true);
HowToRepeatHeaderUsingScript.zip (4.7 KB)
