This recipe shows how to add column with new records using cube.
- Create a blank report template using the given datasource (CrossTab_Pivot.ds).
- Under “Section Header”, add a cube by selecting “Currency” as “Column Dimensions”, and selecting “Date” as “Row Dimensions”. Define cube measures as follows:Name=Rate, Function=Sum, Pattern=${0}
- Select the following options on the “Cube Options” page:Collapse Empty Rows
Collapse Empty Columns
Row Totals After Details
Column Totals After Details
HowToAddColumnWithNewRecord.zip (6.0 KB)
