This recipe demonstrates on sorting group type by passing parameter using Java code.
- Create a report template (PassParameterToGroupSort.rml) using the given datasource (FruitSales.ds).
- Add the following parameters into “Report->Parameters”:(Param1) Name = SortOption, Value = ${SortOption#choice(Company,Fruit)#Company}
(Param2) Name = SortOrder, Value = ${SortOrder#choice(Ascending,Descending)#Ascending}
(Param3) Name=SortGroupOn, Value = ${SortGroupOn#choice(None,Each Value,All)#None} - Add the code into ‘Report->Open Properties->Script-> On Render Begin’:var sortOption = Parameters.get(“SortOption”)
var sortOrder = Parameters.get(“SortOrder”)
var sortGroupOn = Parameters.get(“SortGroupOn”)
var Raw = getSection(0)Raw.getGroup(0).setField(sortOption);
Raw.getGroup(0).setSortOrder(sortOrder);
Raw.getGroup(0).setGroupOn(sortGroupOn);
HowToPassParameterToGroupSort.zip (4 KB)
