These are Javascripting references which can be used in the report template design:
- Addition and Concatenation
- Alternate Colour for Records in the Detail Band
- Charts
- Date Formatting
- Dynamic Content
- Hiding Components
- Import Class
- JavaScript API Reference
- Java Scripting
- Manipulation Of Report Element’s Properties
- MimeType Script
- Not a Number(NaN)
- Page Numbering
- Page Count
- Section Invocation
- Renaming Excel Worksheets
- Sharing Scripts
- System Variable
- Using Scriptlets in Elixir Repertoire Designer/Remote
- Variables with Spaces
- Working with Data Caches
- Linefeed Into An XML Attribute
- User-Defined Function
- Handling NULL Values in CSV
- Calculate number of days in between 2 dates
- Rendering Section Dynamically
- Count Unique
