Standard Javascript utilities can be easily referenced. Includes Formatting and Date Funtions.
Date
function offsetYears(origDate, numYears)
=Code Snippet=
offsetYears(new java.util.Date(), 4)
The above example returns system date (4 years ahead)
Download the DateFunctions sample here. Please change the following .txt to .jar
Number
String formatNumber(Number n, int decimalPlaces)
=Code Snippet=
Format.formatNumber(345886,5)
The above example returns 345,886.00000
String formatNumber(Number n, String pattern)
=Code Snippet=
Format.formatNumber(450000,"#0,K")
The above example returns 450K
*Note that pattern only allows '#,K' or '#0,K'%
Currency
String formatCurrency(Number n, String locale)
=Code Snippet=
Format.formatCurrency(12364,java.util.Locale("de","DE"))
The above example returns 12.364,00€
