Scripting with Chart
To display custom colors for charts(Applicable for: Area, Bar, Column, Pie):
=Code Snippet=
importClass(Packages.com.elixirtech.chart2.custom.CustomDrawingSupplier);
//Diagram of Named Colours available in
//Elixir Report Designer User Manual, Figure 4.2. Name Colours
paints = ["DarkSeaGreen","Gold","LightCoral","CornflowerBlue","GreenYellow"];
cds = new CustomDrawingSupplier();
cds.setPaintNames(paints);
plot.drawingSupplier = cds;
To change the legend’s font:
=Code Snippet=
getLegend().setItemFont(new java.awt.Font("Arial",0,20));
To place the y-axis on the right:
=Code Snippet=
plot.setRangeAxisLocation(Packages.org.jfree.chart.axis.AxisLocation.TOP_OR_RIGHT);
To put a background image on a chart you can use the following script(Applicable for: Area, Bar, Column, Line, Meter, Pie, Polar, Stocks, Waterfall, XY):
For Version 8.1.1 and earlier
See [* org.jfree.ui.Align] options
=Code Snippet=
url = new java.net.URL("repository:/ElixirSamples/Resources/images/LogoElixir.gif");
im = Packages.javax.imageio.ImageIO.read(url);
plot.backgroundImage = im;
plot.setBackgroundImageAlignment(Packages.org.jfree.ui.Align.TOP_LEFT);
// Instead of plot area only, the image can be shown in the entire chart area with:
For Version 8.2.x and later
=Code Snippet=
var is = Packages.com.elixirtech.util.
URLLoader.getInputStream("repository:/ElixirSamples/Resources/images/LogoElixir.gif");
var im = Packages.javax.imageio.ImageIO.read(is);
plot.setBackgroundImageAlignment(Packages.org.jfree.ui.Align.LEFT);
To show colors of a chart based on the values of the field(Applicable for: Area, Bar, Column, Line, Pie):
=Code Snippet=
//Importing the Chart class for usage
var ds = plot.getDataset();
var rows = ds.getRowCount();
var paints = Array();
for (i=0;i<rows;i++)
//ds.getValue() is the values as defined in 'Value' Tab
var value = ds.getValue(i,0);
if (value>500) paints[i] = "Red";
else paints[i] = "Gold";
To add markers for the Line Chart:
=Code Snippet=
importPackage(Packages.com.elixirtech.chart2.plot);
var lineandshaperenderer = plot.getRenderer();
lineandshaperenderer.setShapesVisible(true);
To display patterns instead of color for charts(Applicable for: Area, Bar, Column, Pie):
=(A known issue for version 6.1, please do not use with version 6.1)=
=Code Snippet=
paints = ["Diag","Horiz","Wave","RDiag"];
To remove the labels from the Pie Chart, you can use the following script:
=Code Snippet=
*plot.setLabelGenerator(null);*
To remove the individual legend from the Multiple Pie Chart, you can use the following script:
=Code Snippet=
var chart = plot.getPieChart();
chart.removeLegend();
To include value in Label for Pie Chart, you can include the field name in ‘Key’ tab:
=Code Snippet=
Fruit + " - " + _2000
//where Fruit and 2000 is the Field Name
To include the percentage value on the label for Multiple Pie Chart, you can include the following in ‘Script’ tab:
=Code Snippet=
importClass(Packages.org.jfree.chart.labels.StandardPieSectionLabelGenerator);
var p = chart.plot;
p.setLabelGenerator(new StandardPieSectionLabelGenerator("{0} = {1} ({2})"));
To include the percentage value on the label for Pie Chart, you can include the following in ‘Script’ tab:
=Code Snippet=
var gen = new StandardPieSectionLabelGenerator("{0} = {1} ({2})");
plot.setLabelGenerator(gen);
To include the percentage value on the label for Pie Chart with the decimal format, you can include the following in ‘Script’ tab:
=Code Snippet=
importClass(java.text.DecimalFormat);
var gen = new StandardPieSectionLabelGenerator("{0} = {1} ({2})", new DecimalFormat("0.00"), new DecimalFormat("0.00%"));
To custom format a Date in the Legend’s label, you can include the following in ‘Script’ tab:
=Code Snippet=
importClass(Packages.org.jfree.chart.labels.CategorySeriesLabelGenerator);
var df = new java.text.SimpleDateFormat("dd/MM/yyyy")
function generateLabel(dataset,series)
var data = dataset.getRowKey(series)
return df.format(data)
*plot.renderer.setLegendItemLabelGenerator(generateLabel);*
**To change the font properties for Pie Chart:**
=Code Snippet=
*plot.labelFont = new java.awt.Font("SansSerif",0,18);*
To change the font properties for Meter Chart:
=Code Snippet=
//Font for the Tick Value
plot.setTickLabelFont(new java.awt.Font("SansSerif",0,14));
//Font for the Meter Chart
plot.setValueFont(new java.awt.Font("SansSerif",0,20));
To change the font properties for XY Chart:
=Code Snippet=
*importClass(Packages.com.elixirtech.ui.StandardColor);*
lineandshaperenderer.setItemLabelFont(new java.awt.Font("SansSerif",0,10));
lineandshaperenderer.setItemLabelPaint(StandardColor.lookup("Red"));
lineandshaperenderer.setItemLabelsVisible(true);
XY Chart, to display month abbreviation instead of an integer on the x-axis:
=(Work with Elixir Repertoire 6.2 and above)=
=Code Snippet=
*importPackage(Packages.com.elixirtech.chart2.custom);*
var oldtu = plot.domainAxis.getTickUnit();
var newtu = TickUnitFactory.getShortMonths(true);
var tu = new CustomNumberTickUnit(oldtu,newtu);
plot.domainAxis.setTickUnit(tu);
To add markers for the XY Chart:
=Code Snippet=
importPackage(Packages.org.jfree.chart.renderer.xy);
//new XYLineAndShapeRenderer(boolean line, boolean shape)
plot.setRenderer(new XYLineAndShapeRenderer(true, true));
To change the text orientation for a chart(Applicable for: Area, Bar, Column, Line, Waterfall):
=Code Snippet=
importClass(Packages.org.jfree.chart.axis.CategoryLabelPositions);
domainAxis = plot.getDomainAxis();
* Math.PI / 1 = 180 degree
* Math.PI / 2 = 90 degree
* Math.PI / 4 = 45 degree
* Math.PI * 2 = 360 degree (Default horizontal layout)
mydegree=4;
domainAxis.setCategoryLabelPositions(
CategoryLabelPositions.createUpRotationLabelPositions(Math.PI /mydegree)
To create exploded 2d pie chart on a dashboard:
=Code Snippet=
if (cxt)
// reset explode
var total = plot.getDataset().getKeys().size();
for (var i=0;i<total;i++)
plot.setExplodePercent(i,0);
// explode selected
var sel = cxt.getSelection().nextSetBit(0);
if (sel>=0)
var table = cxt.getDataSource();
var rec = table.getRecord(sel);
plot.setExplodePercent(rec.getData(0),0.2);
//rec.getData(0) refers to the record
In addition, you will need to create an action event that refreshes the chart view on the dashboard on every click.
To dynamic display minimum and maximum values(Applicable for: Meter):
=(Work with Elixir Repertoire 7.2 and above)=
=Code Snippet=
importClass(Packages.org.jfree.chart.plot.MeterInterval);
importClass(Packages.org.jfree.data.Range);
println("A");
if (cxt!=null)
println("B");
var ds = cxt.getDataSource();
println(ds);
println(ds.getRecordCount());
if (ds.getRecordCount()>0)
println("Got record");
var rec = ds.getRecord(0);
var min = rec.getData(ds.getColumnIndex("Min"));
var max = rec.getData(ds.getColumnIndex("Max"));
var name = rec.getData(ds.getColumnIndex("Person"));
var range = new Range(min,max);
plot.setRange(range);
plot.addInterval(new MeterInterval(name,range));
To make the gap of bar chart closer between each axis
importClass(Packages.org.jfree.chart.axis.CategoryAxis);
plot.getDomainAxis().setCategoryMargin(0.5);
To remove the shadow of bar/column chart
var chart = plot.getRenderer();
chart.setShadowVisible(false);
To set auto range of axis for line chart
plot.getRangeAxis(0).setAutoRangeIncludesZero(false);
plot.getRangeAxis(0).setAutoRange(true);
To increase upper Margin for chart
plot.getRangeAxis(0).setUpperMargin(0.2);
To remove item labels
plot.getRePreformatted textnderer(0).setItemLabelsVisible(false);
To make the gap of bar chart closer on each axis
plot.getRenderer().setItemMargin(0.05);
Set the background gradient
var grey = new java.awt.Color(0xA0A0A0);
var white = new java.awt.Color(0xFFFFFF);
var gradient = new java.awt.GradientPaint(0, 0, grey, 0, 200, white);
plot.setBackgroundPaint(gradient);
Set bar chart with gradient
// replace the built-in bar gradient with a flat one, so we can paint our own gradient
importClass(Packages.org.jfree.chart.renderer.category.StandardBarPainter);
plot.getRenderer().setBarPainter(new StandardBarPainter());
var bluer = new java.awt.Color(0x0000DD);
var blue = new java.awt.Color(0x000080);
var gradient2 = new java.awt.GradientPaint(0, 0, blue, 0, 0, bluer);
plot.getRenderer().setSeriesPaint(0,gradient2);
Remove Pie Chart Shadow
plot.setShadowPaint(null);
For Multiple Pie Chart
plot.getPieChart().getPlot().setShadowPaint(null);
Change the shape of the point in the line graph
Use setShape(object) function in jfreechart. To draw a small rectangle for all the markers in the graph, in Script tab of the line graph, put:
lineandshaperenderer.setShape(new java.awt.Rectangle(-1, -1, 2, 2));
To modify the markers of each line, use setSeriesShape(index, object)
lineandshaperenderer.setSeriesShape(0, new java.awt.Rectangle(-1, -1, 2, 2));
lineandshaperenderer.setSeriesShape(1, new java.awt.Rectangle(-1, -1, 2, 2));
lineandshaperenderer.setSeriesShape(2, new java.awt.Rectangle(-1, -1, 2, 2));
lineandshaperenderer.setSeriesShape(3, new java.awt.Rectangle(-1, -1, 2, 2));
To change the bars and lines color in the chart:
In the Colour tab in Chart Wizard, untick the “Automatic generation of legend colors” option so that the customize colors could take effect:
Most scripting explains above can be found in the ChartScripting.jar.
For more information on the available method for Charts, please refer to the API available.
Reference: http://www.jfree.org/jfreechart/
