Migrating from Repertoire 202x to latest 202x build
Prerequisites:
Please ensure you have the license key for Repertoire-202x and to not remove/overwrite your current Repertoire installation directory.
Here are the steps to migrate from Repertoire 202x to the latest 202x build:
  1. Stop/Shutdown the current Repertoire server.
  2. Unzip the latest version of Repertoire 202x.
  3. Edit the new etc/application.conf content base on your previous version of Repertoire/Ambience etc/application.conf (Do not overwrite the application.conf with your existing one).
  4. Move/copy over your DS and RML templates from the /repository to the /repository directory of the new installation.
  5. Rename the bin/run-server from the new Repertoire to bin/run-server.bkup and copy over startup script bin/run-server from the old Repertoire to the new Repertoire directory
  6. Copy over the JDBC driver in /ext directory. Please follow either of these guides to create the connection pool:
  7. Migrate your connection pools, logback config in /etc.Please follow these guides for additional configurations:
  8. Copy over users and groups information under the data/codex directory. Copying over the /data directory from the current Repertoire Server installation to the new Repertoire Server installation will preserve the existing users, roles, chainsets (ETL jobs), and scheduled triggers.
  9. To configure Repertoire 202x as a Linux or Windows service, please follow these guides:
  1. To configure Repertoire 202x to run in HTTPS mode.
    Running Ambience/Repertoire 202x in HTTPS mode - Ambience 2020+ - Elixir Support Forum
Note: To deploy the licence file, you can either log in to the Repertoire Server and upload the license file through the License Deployer, module or place the license file in the /etc folder of your Repertoire Server installation. Ensure the license file is named ElixirRepertoire.license .
