To create an Oracle connection pool on the Ambience 202x Server:
Deploy the ojdbc driver in the \lib or \ext directory of the Ambience 202x installation
Go to \etc directory, make a copy and rename hikari-sample.properties, e.g. oracle.properties
Edit the oracle.properties file as follows:
- dataSourceClassName=oracle.jdbc.pool.OracleDataSource
- dataSource.url=
jdbc:oracle:thin:@<servername>:<port>:<database> - dataSource.user=
- dataSource.password=
Edit application.conf to point to the oracle connection properties. Substitute “sample” with the actual database name e.g.
elixir.data.jdbc {
connection-pool {
implementation = “hikari”
definition {
sample = “./etc/oracle.properties”
You can encrypt the connection pool password by running bin\ambience-cli.bat at the command line, e.g.
\Ambience2020\bin>ambience-cli.bat encrypt password
The command will return the following:
password = {enc}67uXBxd5Ecxp1BvBgQWGew==Go to the properties file and substitute the password, e.g.
dataSource.password= {enc}67uXBxd5Ecxp1BvBgQWGew==
