Elixir Support Forum
Composite Datasource in Repertoire Data Designer
Elixir Repertoire
Repertoire Designer
kaixuan
June 16, 2020, 9:34am
1
Cube Measure’s Pattern
Custom Java Data Store
Filter Processor
Handle Null/empty values in SQL
Lookup Parameter
Date Handling Java Scripts
Run & Deploy your own Java Script as extensions
Using Scripts in Derivative/Filter Processor
Creating Star Schema
Extraction-Transformation-Loading (ETL) and Data Aggregation, Cube and Cleaning
