The following steps allow a component to lookup another datasource parameter’s values.
To give you a feel, the parameterization syntax will support a new “lookup” type as follow:
${Company Name#lookup(Fruit,CompanyName)#B}
This will create a parameter on the UI with label Company Name with a combo box that reads its values from the datasource called Fruit using the field called “CompanyName”. The default selection will be company B.
Further, the datasource “Fruit” can be either:
- the name of a Data Source within a Report (ERD)
- the name of a Graphic Object within a Composite Diagram (Ensemble)
- the name of a View using view: syntax (Perspective)
- the name of a datasource in the Repository (All)
Also, further parameters can be passed in if the datasource requires parameters:
${Company Name#lookup(Fruit,CompanyName,User=Peter,Password=Peter)#B}
This then forms the basis for incorporating Cascading support with:
${Company Name#lookup(Fruit,CompanyName,Country=${Country}#B}
You can allow looking data source in the repository:
${Company Name#lookup( repository:/Sales/Fruit.ds,CompanyName,Country=${Country}#B}
