- In Ambience v2022 & above, you would be able to make use of the Repertoire 202x designer to connect to your Ambience 202x server and retrieve the files from the Repository module.
- Do follow through the steps below as a guide on how to connect the Ambience 202x repository to the designer.
In the etc/application.conf file of your Ambience 202x server, add the following line & save the file.
elixir.sso.server.resource-owner-password-enabled = true -
Restart the Ambience server & Start up the Repertoire 202x designer.
In the designer, click on the following icon as highlighted below to connect to the server.
Next, you will be shown a pop-up which would require you to enter the following details: “Server”, “User Name”, “Password” & “2FA” (if configured)
Click on “Connect” & you should be able to see your Repository tree as configured in Ambience v202x repository module.
