This entry guides you through the steps to send a report template request via REST API from an application.
- This could be achieved either by using option “A. Base-64 Encryption” or option “B. Ambience Generated API token”.
A. Using Base-64 Encryption
- Firstly, declare the report path and output format.
String reportPath = "/ElixirSamples/Report/RML/Pivot%20Table.rml";
String url = "http://localhost:8080/elx/do/eno/re" + reportPath;
String mimeType = "application/pdf";
- Next, send the parameter values in XML format.
String xml = "<report mime-type=\""+mimeType+"\">"+
"<parameters>"+
"\n<parameter name=\"Staff Name\">Joanne Tan</parameter>"+
"\n</parameters>"+
"\n<return filename=\"report\" disposition=\"attachment\"/>"+
"\n</report>";
- Next, log in to the Ambience server
HttpClient httpClient = HttpClients.createDefault();
String encoding = DatatypeConverter.printBase64Binary("admin:sa".getBytes());
- Send POST request to render report template with parameter values.
HttpPost httppost = new HttpPost(url);
httppost.setHeader("Authorization", "Basic " + encoding);
StringEntity se = new StringEntity(xml.toString(), ContentType.APPLICATION_XML);
httppost.setEntity(se);
HttpResponse response = httpClient.execute(httppost);
HttpEntity entity = response.getEntity();
InputStream is = entity.getContent();
File f = new File("test.pdf");
FileOutputStream fos = new FileOutputStream(f);
IOUtils.copy(is, fos);
is.close();
fos.close();
Full Java code sample for Sending Report template request via REST API using Base-64 encryption can be found here (2.1 MB).
1. Firstly, declare the report path and output format. String reportPath = "/ElixirSamples/Report/RML/Pivot%20Table.rml";
String token = "?elx.token=eno:api-d22969d817e9f3688f4b9e0358e88d67";
String url = "http://localhost:8080/elx/do/eno/re" + reportPath + token;
"<parameters>"+
"\n</parameters>"+
"\n</report>";
- Next, declare the HTTPClient
- Send the POST request to render report template with parameter values.
is.close();
fos.close();
Full Java code sample for Sending Report template request via REST API using Ambience Generated API token can be found here (2.1 MB)
