This recipe shows how to merge data by group from XML code, using an XML datasource.
- Create an XML datasource (Grouping.ds).
- Enter the following XML code into the “DataSource Wizard > Data” field:<?xml version="1.0" encoding="ISO-8859-1"?>
MergeByGroup.zip
