This entry explains the rendering differences observed between Repertoire 8.x and Repertoire 202x. The variations are primarily due to changes in Java font metric calculations between Java 8 and newer Java versions.
Vertical Shifting & Spacing of Report Elements
Certain reports may show slight vertical shifts in text blocks. This occurs because of differences in how Java versions calculate text height and line spacing:
Java 8
- Applied an extra leading (line spacing) value at the top of text blocks.
- For auto‑wrap fields, font height metrics (ascent + descent + leading) produced slightly larger line spacing values.
- Example: Identical wrapped text may measure 15 pt line spacing.
Java 9 onwards
- Removed the extra leading at the top of text blocks, applying leading only between lines.
- Adjusted font height metric computation, resulting in smaller inter‑line spacing values.
- Example: Identical wrapped text may measure 14 pt line spacing.
Due to each auto‑wrapped field contributes a minor upward shift (~1 pixel), the effect accumulates further down the page. Fields with fixed height or auto‑wrap disabled remain unaffected.
Premature Text Wrapping
Text wrapping differences are linked to how Java calculates text width:
Java 8
- Relied on logical font metrics during layout, which did not always match the physical font metrics used for rendering.
- Logical font names were mapped internally for layout, while the actual physical font was resolved only at rendering.
- This mismatch caused the layout engine to reserve more width than necessary, leading to early line breaks and unused right‑hand margin space.
- Example: Layout may reserve 200 px, while the rendered text only occupies 160 px.
Java 9 onwards
- Improved alignment between layout width calculation and final rendering.
- Reserved width closely matches rendered width, preventing premature line breaks.
- Text now extends correctly to the full width of the text block, producing more precise rendering behavior.
What This Clarification Achieves
- Explains why vertical shifting and spacing differences occur between Java versions.
- Clarifies the root cause of premature text wrapping in Repertoire 8.10.
- Highlights that Repertoire 2024 rendering behavior is more accurate and consistent with updated Java font metrics.
