This recipe demonstrates how to read data from LOG files using text datasource.
Create a text datasource (Rep7-Server-Log.ds). Enter the file path of server.log into the “Define Text Datasource > File URL” field. Set Encoding to “UTF-8”. Set Date, Time and Timestamp formats properly. Set the “Access Type” to “Regular Expression”.
On the next page, enter the following into the “Regular Expression” field:
Infer schema and click “Finish”.
Create a text datasource (Repertoire_ServerLog_ExtractInfo.ds). Enter the file path of server-2007-04-25.log into the “Define Text Datasource > File URL” field. Set Encoding to “ASCII”. Set Date, Time and Timestamp formats properly. Set the “Access Type” to “Regular Expression”. Select the “First line is header” checkbox.
(.),(.),(.), ERS2.Audit - [byte-size=(.), job-ended=(.), job-owner=(.), job-received=(.), job-started=(.), mime-type=(.), name=(.), page-count=(.), record-count=(.), status-code=(.*)]
RegEx.zip (77.4 KB)
