([^\-]*)\-\s([^\s]*)\s([^\"]*)\"([^\s]*)\s([^\"]*)"\s([0-9]*)\s([0-9]*).*
Apply on access.log file:
([^\-]*) // characters up to dash become first field -
\-\s // dash space -
([^\s]*) // characters up to next space become second field -
\s // space -
([^\"]*) // characters up to quote become third field -
\" // quote -
([^\s]*) // characters up to space become fourth field -
\s // space -
([^\"]*) // characters up to quote become fifth field -
"\s // quote and space -
([0-9]*) // digits become sixth field -
\s // space -
([0-9]*) // digits become seventh field -
.* // anything else on the line ignored
To filter so you only see certain codes, eg. 403 in the sixth field:
([^\-]*)\-\s([^\s]*)\s([^\"]*)\"([^\s]*)\s([^\"]*)"\s(403)\s([0-9]*).*
if you don’t want to see the 403 as a field remove the grouping parenthesis:
([^\-]*)\-\s([^\s]*)\s([^\"]*)\"([^\s]*)\s([^\"]*)"\s403\s([0-9]*).*
To use variable substitution, insert a ${code}
([^\-]*)\-\s([^\s]*)\s([^\"]*)\"([^\s]*)\s([^\"]*)"\s(${code})\s([0-9]*).*
I’ve reinserted the grouping parenthesis in this example, so the actual code value becomes a field.
