Implementation of QR-Codes can be achieved through the use of Google’s chart API by placing an image element on the template and defining its “Image Type” as “Script” under the “Image” tab of its properties. Input any of the following in the scripting field, replacing the parameters with your own:
[URL] Hard-coded
[URL] reading values from parameters
[URL] reading values from datasource columns
Requirements:
The machine that is rendering the report template with the QR-Codes must have an Internet connection to access the Google chart API.
More info is available here:
http://google-code-updates.blogspot.com/2008/07/qr-codes-now-available-on-google-chart.html
Sample:
A sample can be obtained “%ATTACHURL%/Report-With-QRCode.jar”. Copy the .jar file to your /ext of your Repertoire Designer or add it to your file system to view the example.
