System Requirements
Supported Platforms
Elixir Repertoire supports any Java SE version 8 Runtime Environment (JRE) compliant platforms such as the following:
  • Windows
  • Solaris
  • Linux
  • Macintosh OS X
Software Requirements
Elixir Repertoire requires the following software to run. Please make sure you install the software prior to installing Elixir Repertoire:
  • The software requires a Java SE version 8 Runtime Environment (JRE) or later. If you do not have Java pre-installed, please download and install it from http://java.sun.comjavase/downloads/index.jsp or from your preferred vendor.
  • Client browser: IE, Edge, Chrome or Firefox
  • Adobe Acrobat PDF viewer plug-in on the client web-browser
Hardware Requirements
Elixir software is able to run on a usual entry level system available in the market. As long as the operating system and the Java runtime is able to operate smoothly, Elixir software itself only requires an incremental amount of RAM. The primary demand for hardware resources comes from the volume of data retrieval (requiring more RAM), the complexity of rendering logic (speed of processor will benefit), and concurrency of rendering (multiple processors or cores will help).
JDK Requirements
Elixir Repertoire is able to run on the JDK listed below:
  • IBM JDK 8
  • Oracle JDK 8 and 11
  • Open JDK 8 and 11
For Elixir Repertoire Professional
A recommended minimum configuration would be 512MB or 1GB for higher usage or more complex report template designs.
A minimum of 500MB disk space is recommended for the following:
  • Elixir Repertoire software, documentations and samples.
  • Java runtime (depending on the version)
  • Reserved space for other 3rd party add-on software like database drivers.
For Elixir Repertoire Server
Minimum Intel® Pentium® 4 Processor with 800MHz or more is required.
A recommended minimum configuration would be 1GB or 2GB and above for more advanced usage.
A minimum of 500 MB disk space is recommended.
This consists of the following:
  • Elixir Repertoire Server software, documentations and samples.
