Setting Up Two-Factor Authentication (2FA) in Ambience/Repertoire
Users can configure their own Two-Factor Authentication (2FA) once the option has been enabled globally in the application.conf file. Ambience/Repertoire 202x supports TOTP (Time-based One-Time Password) authentication using standard authenticator apps.
Configuration Steps:
  1. Open up application.conf and add the configuration below:
    ambience.user-settings.enable-panel.totp = true
  2. Under simple-server.clients.ambience, locate show-totp and set it to true. This enables the TOTP option at the login screen.
  3. User Setup in Report Portal (Please restart the server after making the above changes)
  1. Register with Authenticator App
  • Open a TOTP authenticator app (e.g., Google Authenticator) on your phone.
  • Scan the QR code.
  • The app will register as ElixirAmbience (username) and generate a 6-digit code that refreshes every 30 seconds.
  • Ambience allows a one-minute window for clock drift. Ensure your phone and server clocks are in sync.
  1. Confirm Setup
  • Enter the 6-digit code (with or without spaces) and click Confirm.
  • Once successful, the TOTP 2FA Enabled panel will appear.
  • Incorrect or incomplete codes will trigger error messages.
  1. Testing 2FA
  • Log out and log back in.
  • You will be prompted for the 2FA code.
  • Entering an incorrect code will display an error in the login dialog.
Disabling 2FA
  • Open up the user settings and click on the 2FA tab
  • Enter the current 6-digit code and click Disable.
  • A notification will confirm that 2FA has been disabled.
  • If you have the mod-identity privilege, use the Identity module to reset 2FA for a user.
