Selenium with Firefox Configuration Guide for Repertoire 2024/2025
Introduction
This guide provides detailed instructions for configuring Selenium with headless Firefox in Ambience/Repertoire 2024 and 2025, including setting up the GeckoDriver, adjusting application settings, and applying a custom CSS style for consistent rendering.
Available Versions
- Repertoire 2024: Supports
elx-rml-runtime_3-8.0.7.jar - Repertoire 2025: Supports
elx-rml-runtime_3-8.0.12.jar
Prerequisites
Firefox Version: 56 or above (recommended for headless mode)
GeckoDriver: Download from Mozilla’s official release:
GeckoDriver v0.36.0 -
Custom Elixir JAR Files:
- A2024: Download Link
- A2025: Download Link
Installation Steps
1. Set Up GeckoDriver
- Download the appropriate GeckoDriver version.
- Place the driver in the
ext/directory of Repertoire Designer or Server.
2. Update Configuration (application.conf)
- Locate and edit the
etc/application.conffile. - Add the following configuration:
elixir.rml.image.scripted-can-grow = true
com.elixirtech.selenium {
firefox-driver = "/<full-path>/ext/geckodriver"
firefox-profile = [
"layout.css.devPixelsPerPx=2"
firefox-args = [
"--headless"
- Ensure the
firefox-driverpath points to the correct location of your GeckoDriver.
3. Set Up Custom CSS Style (Optional)
- Create a
style.htmlfile with your desired CSS:
style.html must exist on all environment regardless for this to work
<style>
table {
border-collapse: collapse;
width: 100%;
border: 2px solid rgb(183, 116, 30);
background-color: #e27c0e;
th, td {
border: 1px solid rgb(183, 86, 31);
padding: 8px;
text-align: left;
th {
background-color: #df640b;
color: #de9605;
font-weight: bold;
</style>
- Update
application.confto use this CSS file:
com.elixirtech.selenium.firefox-head-file = "/<path-to-file>/style.html"
- Restart the Repertoire Server or Designer for the changes to take effect.
Script Usage in Designer
Sample Script (getImageAndHeight)
importClass(Packages.com.elixirtech.selenium.FirefoxRunner);
var html = "<div style='color: blue; background-color: yellow; border: 3px solid red; font-size:2rem;'>" +
"Hello World<br>This time spanning multiple lines<br>so that we can test growth " +
"and the height<br>adjustment while rendering" +
"</div>";
var scale = 2;
var ih = FirefoxRunner.getImageAndHeight(this.getWidth() / 20 * scale, html);
this.setHeight(ih.getHeight() * 20 / scale);
ih.getImage();
render begin script(must have):
// this comment must exist,
// else "this" is not available in the image script.
- Set the
scalevalue to match thelayout.css.devPixelsPerPxvalue in your configuration. - Ensure your script has a “Render Begin” comment to avoid execution issues.
Understanding the Script
- The script calculates the image width based on the component width.
- It then uses the height value to set the component height, maintaining a consistent scaling factor.
Troubleshooting
- Ensure the GeckoDriver path in
application.confis correct. - Make sure the CSS file is present on all machines where Repertoire is running.
- Restart the server/designer after making any CSS or configuration changes.
