[Schedule Designer] How To Select Report To Generate
Rendering report job - Job to be able to render reports based on report templates requested.
From the 3rd party application point of view, a UI listing down all the possible report templates is created.
The UI allows the end-user to multiple-select the set of templates to be sent for generation.
This set of templates should then be translated as a JSON string to be sent to the Repertoire Server.
HTTP : POST
http://localhost:8080/job/Elixir/ER_Cookbook/Schedule-Designer/HowToSelectReportToGenerate/Master.job?
list=[{“rml”:“repository:/ElixirSamples/Report/Charting/3D Visualization.rml”,“print_status”:“Y”},
{“rml”:“repository:/ElixirSamples/Report/Charting/Chart with Scripting.rml”,“print_status”:“N”}]
  • A JavaObject Datasource would be required to read in the JSON string.
  • This job would dataloop and filter all the reports with status = ‘y’ and push the records to a RenderReport Task
  • The output is then collected at a targeted folder ( e.g C:\temp )
  • The end user would then be redirected to pick up the generated output at this location.
HowToSelectReportToGenerate.zip (3.5 KB)
