Running Ambience202x & Mongod 6.0.4 as a Service RHEL 8.7
Archive
Ambience2022.1
OpenJDK17
OpenJRE17
Mongod 6.0.4 with mongodump
Default: Mongod configuration files
Remove extension. .txt and import mongod.conf in your home directory and mongod.service in /usr/lib/systemd/system/
mongod.conf.txt (844 Bytes)
mongod.service.txt (977 Bytes)
Default: Run ambience as a service
Rename extension to .service and import the file to /usr/lib/systemd/system/
elx-ambience.service.txt (265 Bytes)
Part 2 Run mongod as a script
Rename extension to .sh and import the script to /etc/init.d/
mongodasascript.txt (1.8 KB)
Part 2.1 Create and run mongod as a service
Rename extension to .service and import the script to /etc/systemd/system/
mongodasasservice.txt (247 Bytes)
Part 3 Run mongod as a service file as su
Rename extension to .service and import the file to /etc/systemd/system/
mongodasaservicesu.txt (883 Bytes)
Automated Script
Select non-default archive files
select.sh.txt (5.1 KB)
Park, enable, and start affected services
start.sh.txt (702 Bytes)
Walkthrough
how to run rhel mongo and ambience202x in 10 mins.mp4
