The following example demonstrates how an authenticated user is able to log onto the Repertoire Server from the application through the REST API to generate data using a datasource.
The parameters required to be parsed in are:
1/ The url of the data source on the server, e.g. “https://localhost:8443/data/Elixir/ER_Exercises/Application-Integration/samples/datasources/FruitSales.ds”
2/ The output path and filename for the rendered file
3/ User name and password
Within the Java class environment import the following Java references:
import java.io.BufferedInputStream;
import java.io.FileOutputStream;
import java.io.InputStream;
To talk to the server via the REST API add the following .jar files from the “/lib” directory of the Repertoire Server installation:
commons-codec-1.3.jar
commons-httpclient-3.0.1.jar
commons-logging.jar
and import them into the class file:
import org.apache.commons.httpclient.Credentials;
import org.apache.commons.httpclient.Header;
import org.apache.commons.httpclient.HttpClient;
import org.apache.commons.httpclient.UsernamePasswordCredentials;
import org.apache.commons.httpclient.auth.AuthScope;
import org.apache.commons.httpclient.methods.GetMethod;
import org.apache.commons.httpclient.params.HttpClientParams;
For logging purposes the method getResponseHeaders() is used which is similar to the IJobInfo found in the ERSClient:
Header[] headers = method.getResponseHeaders();
for (Header header : headers) {
System.out.println( header.getName());
System.out.println( header.getValue());
//Opens a connection and sends the credentials
//to the Repertoire Server
try {
HttpClient client = new HttpClient();
Credentials defaultCreds = new UsernamePasswordCredentials(username,password);
client.getState().setCredentials(new AuthScope(“localhost”,8443,AuthScope.ANY_REALM), defaultCreds);
HttpClientParams params = client.getParams();
params.setCredentialCharset(CredentialCharset);
params.setAuthenticationPreemptive(true);
//Instantiate a new GET method and redirect to
//to the target URL
GetMethod method = new GetMethod( url );
method.setFollowRedirects( true );
// Execute the GET method
int statusCode = client.executeMethod( method );
if( statusCode != -1 ) {
System.out.println( “Reading file” );
InputStream is = method.getResponseBodyAsStream();
BufferedInputStream bis = new BufferedInputStream( is );
FileOutputStream fos = new FileOutputStream( filename );
byte[] bytes = new byte[ 8192 ];
int count = bis.read( bytes );
while( count != -1 && count <= 8192 ) {
System.out.print( “-” );
fos.write( bytes, 0, count );
if( count != -1 ) {
//Information regarding the request is return as the response header
//Once completed the File and Buffered
//output streams are closed
fos.close();
bis.close();
method.releaseConnection();
System.out.println( “\nDone” );
catch( Exception e ) {
e.printStackTrace();
Download the following attachment to view the code. Please change the file to .java
GetSecureAuthData.txt
