The following example demonstrates how an authenticated user is able to log onto the Repertoire Server from the application through the REST API to generate a data store using a specific datasource.
The parameters required to be parsed in are:
1/ The url of the composite data source on the server, e.g. “https://localhost:8443/data/Elixir/ER_Exercises/Application-Integration/samples/datasources/FruitSales.ds”
2/ The output path and filename for the data store
3/ User name and password
Within the Java class environment import the following Java references:
import java.io.BufferedInputStream;
import java.io.FileOutputStream;
import java.io.InputStream;
To talk to the server via the REST API add the following .jar files from the “/lib” directory of the Repertoire Server installation:
commons-codec-1.3.jar
commons-httpclient-3.0.1.jar
commons-logging.jar
and import them into the class file:
import org.apache.commons.httpclient.Credentials;
import org.apache.commons.httpclient.HttpClient;
import org.apache.commons.httpclient.UsernamePasswordCredentials;
import org.apache.commons.httpclient.auth.AuthScope;
import org.apache.commons.httpclient.methods.PostMethod;
import org.apache.commons.httpclient.params.HttpClientParams;
HttpClient client = new HttpClient();
Credentials defaultCreds = new UsernamePasswordCredentials(username,password);
client.getState().setCredentials(new AuthScope("localhost",8443,AuthScope.ANY_REALM), defaultCreds);
HttpClientParams params = client.getParams();
params.setCredentialCharset(CredentialCharset);
params.setAuthenticationPreemptive(true);
//Instantiate a new POST method and parse
//in the parameters for the rendering of a
//data store via a composite data source
PostMethod method = new PostMethod( url );
method.addParameter("datastore", "DataStore");
method.addParameter("URL", filename);
// Execute the POST method
int statusCode = client.executeMethod( method );
if( statusCode != -1 ) {
System.out.println( "statusCode: " + statusCode );
method.releaseConnection();
System.out.println( "\nDone" );
catch( Exception e ) {
e.printStackTrace();
Below are explanations and walk throughs of the code. The full Java class can be downloaded POSTSecureAuthDataStore.txt
Please change the following .txt file to .java
