This entry guides you through on how to overcome the following “merged blank cell” issue below when rendering to an XLSX output.
For Elixir Ambience
- Navigate to your
\etcdirectory of your Ambience installation & edit the ‘application.conf’ file. - In your application.conf file, add the following line, vm-args = [“-Delx.xlspipeline.merge-trailer=no”] to each of your job engine.
- For example,
local-job-engines = [
name = “first”
domain = ${domain}
#vm-args is optional, you can include strings here such as
#[“-Xmx6G”, “-server” ] or leave it out completely
For Elixir Repertoire
- Navigate to your
\configdirectory of your Repertoire Server’s installation and edit the ‘EREngine-config.xml’ file. - In your EREngine-config.xml file, ensure the following property value is set to ‘no’.
- For example
<properties>
<property name=“elx.xlspipeline.merge-trailer” value=“no”/>
</properties>
