[Random DataSources] Customized Quarter
This recipe demonstrates how to display quarter based upon random dates.
Create a random datasource (Random Dates.ds). In the “Define Random Datasource” page, add the following column:
Column Name=Date, Data Type=Date, Value Type=Expression, Range from 2004-01-01 to 2008-12-31
Create a composite datasource (Quarters.ds). Drag the random datasource into it as the beginning of the flow.
Add a Sort element following the random datasource. Add the following column into the “Sort” page:
Column Name=Date, Sort Order=Ascending, Group On=Quarter, Field=Q
Add a Derivative element following the Sort element. Add the following columns into the “Derivative > Base” page:
Column 1 Name=Date, Type=Date
Column 2 Name=Q, Type=Integer
Add the following column into the “Derivative > Derived” page:
Column 1 Name=Q, Type=String, Value=“Q”+(Q==0 ? 4 : Q)
Add a Sort element following the Derivative element. Add the following column into the “Sort” page:
Column Name=Q, Sort Order=Ascending, Group On=None
Upon loading data, it will display the random dates and relevant quarter information.
CustomizedQuarter.zip
