| Product Features | Repertoire 8.x.x | Repertoire 202x.x | Ambience 4.x | Ambience 202x.x |
| RML Reports | ||||
| DOCX Reports | ||||
| Scheduler | Limited | Limited | ||
| API Support | Limited | Limited | ||
| Data Processing (ETL) | Limited | |||
| Dashboards | Limited | |||
| Ad hoc Report | Limited | |||
| Ad hoc Dashboard | Limited | |||
| Data Integration | Limited | |||
| DOCX to PDF Converter | ||||
| Geographical Information Systems (Maps) | ||||
| Deep Learning Support | ||||
| Forms and Workflow Engine | ||||
| User Editable Record Editor (works with transient) | ||||
| Data Catalog | ||||
| Report Job Queue | ||||
| Queue Monitor | Limited | |||
| Report Portal | Limited |
Tick refers to a full feature set whereas limited means that it is only a subset of the full features. For example, with APIs, in Ambience 202x.x , we also provide endpoints to remotely run ETL, publish data, post data, and download byte files (e.g. xlsx, pdf etc)
Server deployment comparison between Ambience and Repertoire 202x can be found
here (350.6 KB).
Notes:
Repertoire 8.10 will be the last build of the version 7.x and 8.x architecture (Java 8 and below), Repertoire 2023 is built on Java 11 libraries onwards.
Repertoire 2024 is build on Java 17 libraries (recommended Java 21)
Ambience/Repertoire 2025 supports up to Java 21
Here are the online documentation links for Repertoire 202x:
https://docs.elixirtech.com/Repertoire/2024.0/index.html
https://docs.elixirtech.com/RepertoireDesigner/2024.0/index.html
Here are the online documentation links for Ambience 202x:
https://docs.elixirtech.com/Ambience/2024.0/index.html
