This support entry outlines all the modules available across Repertoire 202x versions, highlighting the differences between them.
| Module (Feature) | Repertoire 2023.x | Repertoire 2024.x | Repertoire 2025.x | Repertoire 2026.x |
| API Tokens | ||||
| Banners | ||||
| DocX Report Engine | ||||
| DS Engine | ||||
| ETL | ||||
| ETL Designer | ||||
| Identities | ||||
| Licence Deployer | ||||
| Privileges | ||||
| Redirect | ||||
| Repository | ||||
| RML Engine | ||||
| Roles | ||||
| Scheduler | ||||
| Service Chooser | ||||
| Simple SSO | ||||
| System Information | ||||
| User Settings | ||||
| Users | ||||
| A4 Migration | ||||
| ETL Daemon | ||||
| Queue Monitor | ||||
| Report Portal | ||||
| Secrets | ||||
| System Settings | ||||
| Text Templates | ||||
| Designer Integration | ||||
| Lookup |
Key Evolution Highlights:
2023 → 2024: Added A4 Migration, ETL Daemon, Queue Monitor, Report Portal, Secrets, System Settings, Text Template(s).
2024 → 2025: Added Designer Integration, Lookup.
2025 → 2026: No new modules added, 2026 continues with the full set introduced in 2025.
2026: Matches 2025 exactly, representing the current complete set of modules.
