Parameter Transformation Using an ETL Chainset
This entry explains how to configure an ETL chainset to transform/calculate parameter values before executing a database query. The example demonstrates adjusting START_DATE and END_DATE when REPORT_TYPE = 'M'.
1.MainChain Chain
The MainChain takes in the parameter values and controls the overall flow. It accepts JSON records with parameters (report name, report type, MIME type, start date, end date).
  • Equal Value - This step compares REPORT_TYPE against 'M' and outputs a boolean result (true/false).
  • Chain If Else - Based on the result of the check, the record is routed into either the transformation chainset (02_If_Report) or the normal execution chainset (03_Else_Report). This ensures that only records with REPORT_TYPE = 'M' undergo parameter modification.
  • HTTP Endpoint – Returns the rendered results to the client, reflecting either transformed or original parameters depending on the input.
2. If_Report Chain
  • This chain is triggered when the condition REPORT_TYPE = 'M' is met. It applies a series of Date Add/Subtract operations to calculate the previous month’s date range (with flexibility to adjust by day, month, or year depending on requirements).
  • Once the adjusted values are computed, the adjusted START_DATE and END_DATE fields are discarded, and the original values are replaced with the new values.
3. Else_Report Chain
  • Triggered when REPORT_TYPE ≠ 'M'. This branch uses the existing START_DATE and END_DATE values without modification, and the report executes with the original parameters.
Example input:
And its corresponding output:
The chainset and a sample RML file are attached to this guide for reference.
sample files.zip (3.0 KB)
