This recipe shows how to use regular expressions in an object datasource.
- Create an object datasource (RegEx.ds).
- Enter the following script into the “DataSource Wizard > JavaScript” tab page:function pushTo(/PushContext/ cxt, /DataListener/ dl)
dl.startData(this);
var input = “${Data##Ref,Ref,Ref,Ref,Ref,Ref,Ref,Ref,Ref,Ref,Ref,Ref,Ref,Ref,Derivative,Discard,Derivative,Derivative,
ParameterSupplier,ParameterSupplier,Derivative,Derivative,Derivative,ParameterSupplier,ParameterSupplier,Derivative,
Derivative,Derivative,ParameterSupplier,ParameterSupplier,Derivative,Derivative,Derivative,Concat,Derivative,Derivative,
ParameterSupplier,Processor,Group,Cube,Derivative,Discard,Derivative,Derivative,Derivative,Filter,Processor,Derivative,
Discard,Derivative,Derivative,ParameterSupplier,ParameterSupplier,Derivative,Derivative,Derivative,ParameterSupplier,
ParameterSupplier,Derivative,Derivative,Derivative,Concat,Derivative,Derivative,ParameterSupplier,Processor,Group,Cube,
Derivative,Discard,Derivative,Derivative,Derivative,Filter,Processor,Concat}”//var input = “a) Apple b) Boy c) cat d) dog e) elephant”;
var ss = input.split("${delimiter}");
for (var i=0;i {
var rec = this.newRecordInstance();
var data = rec.getData();// process record using ss[i]
data[0] = ss[i];
dl.processRecord(rec);
dl.endData(this);
3. When it’s loading data, enter “a”, “b”, or “c” into the delimiter. You will see the different outputs.
RegExInObj.zip
