This recipe shows how to display patient list by birth year using Object DataSource.
Important: Please remember to drop Patient.jar into the ext folder.
- Create an Object DataSource (dsPatient_List_By_BirthYear.ds).
- In the “DataSource Wizard > JavaScript” tab, enter the following script:function pushTo(cxt,dl)
dl.startData(this);
importClass(Packages.demo.Clinic);
//Selection using start year to end year
var start = new java.lang.Integer(${begain##1950});
var end = new java.lang.Integer(${end##1960});
var dIter =new Clinic().getPatients(start,end);
while (dIter.hasNext())
rec = this.newRecordInstance();
data = rec.getData();
dataObj = dIter.next();
data[0] = dataObj.getAddress();
data[1] = dataObj.getID();
data[2] = dataObj.getYearOfBirth();
data[3] = dataObj.getFirstName();
data[4] = dataObj.getLastName();
data[5] = dataObj.getSex();
dl.processRecord(rec);
dl.endData(this);
} - Create a report template (Patient_List_By_BirthYear.rml) using the Object DataSource. Upon rendering, the patient list according to birth year will display.
Patient.zip
