The recipe illustrates how variables are used within the lookup processor.
Remember that the fieldname itself, can be reference as a parameter, like add the “${” and “}” syntax.
- Create a composite datasource (cmps-Employee.ds). Drag and drop sav-Employee.ds as the beginning of the flow.
- Add a “Filter” element following sav-Employee.ds. Make the following settings within the “Filter” element:Column Name=position_title, Type=String, When=Equals, Condition=${position_title}
- Add a “Parameters” element following the “Filter” element. Name it “Lookup” and select the “Iterate” checkbox.
- Drag and drop sav-Employee-position_title.ds into the blank area above the flow. Draw a flow between sav-Employee-position_title.ds and the “Parameters” (Lookup) element.
To download the necessary files for this recipe, refer to the attached ZIP file.Lookup-2.zip
