The following recipe illustrates how to make use of the lookup processor to return an X value based on Y selection.
Very frequently, we would like to present users with user-friendly messages for inputting. However, a totally different set of values need to be sent to the database or other data activities.
This can be achieved using 2 filter processor + 1 lookup.
- Create a composite datasource (Composite.ds).
- Drag and drop Condition.ds into the composite datasource, and make it the beginning of the flow. Add a “Filter” element following Condition.ds. Make the following settings in “Filter > Filter #1”:Column Name=Option, Type=String, When=Equals, Condition=${Option#choice(Active,Closed,All)#}
- Drag and drop Product.ds into the blank area below Condition.ds, and make it the beginning of another flow. Add a “Filter” element following Product.ds. Make the following settings in “Filter > Filter #1”:Column Name=Status, Type=String, When=Matches, Condition=${whereVal}
- Add a “Parameters” element and draw flows between this element and both “Filter” elements. Enter “Lookup” as the “Parameters” element name.
Lookup-1.zip
