In Elixir Ambience 202x, apart from the log files found in the /log directory of your Ambience server installation folder, there are 3 different modules in which could be used for troubleshooting whenever needed. These modules are as follows:
- Activity Logs
- Audit Logs
- Event Logs
Activity Log
- The activity log allows you to view historic Ambience data generation and report rendering activities.
- For more details, do refer to the following documentation link here.
Audit Log
- The audit log allows you to view the actions that was carried out in Ambience.
Event Log
- The event log viewer allows you to view the events that were logged in Ambience.
- For more details, do refer to the following documentation here.
Others
In Ambience 202xx, the logs have also been streamlined for easier reference. (i.e. logs will be categorized by dates)
