Greenplum Database is actually an array of individual database instances running on different servers or hosts, all working together to present a single database image. The master is the entry point to the Greenplum Database system. It is the database instance where users and client applications connect and execute SQL commands. The master coordinates the work amongst the other database instances in the system; the segments, which is where the data resides. Since Greenplum Database is based on PostgreSQL, end-users interact with Greenplum Database (through the master) using JDBC Drivers for PostgresSQL.
JDBC Driver
Java Database Connectivity (JDBC) is an API for connecting programs written in Java to database management systems (DBMS). The API lets you encode access request statements in SQL that are then passed to the database server. The PostgreSQL driver for JDBC is called pgjdbc and can be downloaded from:
Documentation for the JDBC driver is located at:
It is important to choose the correct driver version based on the Java Runtime your application is based on. Below is a quick summary from Postgresql website
- JDK 1.4, 1.5 - JDBC 3. This contains support for SSL and javax.sql but does not require J2EE as it has been added to the J2SE release.
- JDK 1.6 - JDBC4. Support for JDBC4 methods is limited. The driver builds, but the majority of new methods are stubbed out.
Deployment of Postgresql Driver in Repertoire Server
Once you have identified the correct version of the Postgresql driver, the system administrator of the Repertoire Server would need to deploy the Postgresql driver into the RepertoireServer /ext folder.
The Repertoire Server needs to be restarted. (Note that for using Query Builder through Remote Designer, the Postgresql driver DO NOT need to copy to the client’s JRE environment.)
Allowing external client connection to Greenplum Database
By default, connection to the Greenplum database is restricted to the only localhost. Configuration files need to be modified before a successful connection can be achieved. Failure to do so would result in the following Java exception
Caused by: org.postgresql.util.PSQLException: FATAL: missing or erroneous pg_hba.conf file
at org.postgresql.core.v3.ConnectionFactoryImpl.doAuthentication(ConnectionFactoryImpl.java:276)
at org.postgresql.core.v3.ConnectionFactoryImpl.openConnectionImpl(ConnectionFactoryImpl.java:95)
at org.postgresql.core.ConnectionFactory.openConnection(ConnectionFactory.java:66)
at org.postgresql.jdbc2.AbstractJdbc2Connection.<init>(AbstractJdbc2Connection.java:124)
at org.postgresql.jdbc3.AbstractJdbc3Connection.<init>(AbstractJdbc3Connection.java:30)
at org.postgresql.jdbc4.AbstractJdbc4Connection.<init>(AbstractJdbc4Connection.java:29)
at org.postgresql.jdbc4.Jdbc4Connection.<init>(Jdbc4Connection.java:24)
at org.postgresql.Driver.makeConnection(Driver.java:386)
at org.postgresql.Driver.connect(Driver.java:260)
at com.elixirtech.data2.datasource.jdbc.JDBCConnector$Driver.getConnection(Unknown Source)
... 23 more
Therefore the following configuration file changes need to be executed.
-postgresql.conf - Insert
listen_addresses = '*' // This allow Greenplum Database to accept connection from all IP address.
-pg_hba.conf - Insert
host all all <your IP address> md5 // This allows your IP address to connect to Greenplum Database.
