This recipe demonstrates how to implement Row Delimiter/Field Separator using JavaScript in a composite datasource.
- Create a composite datasource (test(t).ds). Drag and drop the tabular datasource (test.ds) as the beginning of the flow.
- Add a “Processor” element following the tabular datasource. Select “General > JavaScript”. Enter the following script in the “processRecord” tab page:var tokens = test.split("@@");for ( x in tokens)
var out = this.newRecordInstance();
var outData = out.getData();
outData[0] = tokens[x];
next.processRecord(out);
} - Add another “Processor” element following the tabular datasource. Select “General > JavaScript”. Enter the following script into the “processRecord” tab page:var tokens = test.split("||");{
outData[0] = tokens[0];
outData[1] = tokens[1];
Sample2 (2).zip
