This recipe shows how to use the Base64.js file in the report template.
- Create a report template (Base64.rml).
- Add the following script into “Report Properties > On Render Begin”:importScript("/Elixir/ER_Cookbook/lib/Base64.js");
function make_base_auth(user, password) {
var tok = user + ‘:’ + password;
var hash = Base64.encode(tok);
return "Basic " + hash;
} - Add the following script into “Data Field (Type: Script)” in the report template Layout page:var url = “http://localhost:8080/data/ElixirSamples/DataSource/FruitSales.ds”;
var auth = make_base_auth(“admin”,“s”);
auth;
//xml = new XMLHttpRequest();
//xml.setRequestHeader(“Authorization”, auth);
//xml.open(“GET”,url)
//xml.responseXml;
Base64.zip (2.4 KB)
