This guide explains how to increase the Java heap memory allocation for Elixir Repertoire by modifying the startup script. Adjusting heap settings can improve performance for large reports, memory-intensive chains, or high-concurrency environments.
Step 1: Locate the Startup Script
Navigate to your Elixir Repertoire 202x/Ambience 202x installation directory.
Open the
/binfolder. -
Locate the appropriate script:
Repertoire 202x:
startServer.shfor Linux/macOSstartServer.batfor Windows
Ambience 202x:
run-server.shfor Linux/macOSrun-server.batfor Windows
Step 2: Configure Heap Parameters
Edit the startup script to include custom Java memory options, e.g:
java -Xms1024M -Xmx3072M -XX:MetaspaceSize=256M -XX:MaxMetaspaceSize=512M -jar RepertoireServer-Launcher.jar
Parameter Breakdown:
-Xms1024M: Sets the initial heap size to 1024 MB. -
-Xmx3072M: Sets the maximum heap size to 3072 MB. -
-XX:MetaspaceSize=256M: Sets the initial metaspace threshold to 256 MB.Note:Metaspace is used to store class metadata such as class definitions, methods, and related runtime information. -
-XX:MaxMetaspaceSize=512M: Sets the maximum metaspace size to 512 MB.
You may adjust these values based on your server’s available memory and workload requirements.
Step 3: Save and Restart
- Save your changes to the script.
- Restart the Repertoire/Ambience server using the updated startup script.
Step 4: Verify Configuration
After restarting:
- Monitor memory usage via system tools or Java profiling utilities.
- Check server logs for any memory-related warnings or errors.
