The steps below are to include sub reports in a report template:
1. Add Subreport Comment Markers
These markers define the section of the main report where the sub-report will be embedded:
Subreport Begin Marker
Add the following marker where the sub-report begins in the template:/Elx/Detail/Sub -
Subreport End Marker
Add this marker at the point where the sub-report ends:/Elx/End/Sub
2. Map Subreport Data Source
To ensure the sub-report pulls the correct data, configure its data source:
Define the Data Source Name
Specify the sub-report’s data source using this path. For example:/Elx/DataSource/Subreport/Name/DocX_Samples/DocX/datasource/FilteredOrderDetails.dsEnsure the .ds file aligns with the required dataset for the sub-report.
Add the Subreport Parameter
Include a parameter that links the sub-report to the main report’s data. For example:/Elx/DataSource/Subreport/Parameter/OrderID/${=ID}This parameter dynamically retrieves the OrderID value from the main report to filter the sub-report data.
3. Verify Subreport Integration
After adding the markers and mapping the data source, confirm the following:
- The sub-report renders within the designated area of the main report.
- The parameter mapping correctly passes data from the main report to the sub-report.
- All formatting and layout align with the specified requirements.
Sub report DOCX sample.zip (15.9 KB)
