This is an example of how to Import/Export configurations from the Domain Admin by calling Ambience Server API using PowerShell.
1. Export Domain Configurations
Notes:
// Do change the following text/value accordingly.
[Username], [Password], [cookie-name], [cookie-value], [cookie-domain], [file-name]
API Structure:
[protocol] :[host] :[port] /elx/dm/[domain] /vivace/export-content/For example,
http://localhost:8080/elx/dm/eno/vivace/export-content/PowerShell cmdlet to download configurations:
$uri = 'http://localhost:8080/elx/dm/eno/vivace/export-content/' $User = "[Username]" $Pw = "[Password]" $base64AuthInfo = [Convert]::ToBase64String([Text.Encoding]::ASCII.GetBytes("$($User):$($Pw)")) $Header = @{ Authorization = "Basic $base64AuthInfo" } $session = New-Object Microsoft.PowerShell.Commands.WebRequestSession $cookie = New-Object System.Net.Cookie $cookie.Name = "[cookie-name]" $cookie.Value = "[cookie-value]" $cookie.Domain = "[cookie-domain]" $session.Cookies.Add($cookie); Invoke-WebRequest $uri -Headers $Header -Method Post -WebSession $session -OutFile [file-name].xml -Verbose
2. Import Domain Configurations
Notes:
[Username], [Password], [cookie-name], [cookie-value], [cookie-domain], [file-name], [path-to-file]
API Structure:
[protocol]:[host]:[port]/elx/dm/[domain]/vivace/import-content/For example,
http://localhost:8080/elx/dm/eno/vivace/import-content/PowerShell cmdlet to upload configurations:
$uri = "http://localhost:8080/elx/dm/eno/vivace/import-content/" $FilePath = "[path-to-file]" $User = "[Username]" $Pw = "[Password]" $base64AuthInfo = [Convert]::ToBase64String([Text.Encoding]::ASCII.GetBytes("$($User):$($Pw)")) $Header = @{ Authorization = "Basic $base64AuthInfo" } $session = New-Object Microsoft.PowerShell.Commands.WebRequestSession $cookie = New-Object System.Net.Cookie $cookie.Name = "[cookie-name]" $cookie.Value = "[cookie-value]" $cookie.Domain = "[cookie-domain]" $session.Cookies.Add($cookie); $fileBytes = [System.IO.File]::ReadAllBytes($FilePath); $fileEnc = [System.Text.Encoding]::GetEncoding('UTF-8').GetString($fileBytes); $boundary = [System.Guid]::NewGuid().ToString(); $LF = "`r`n"; $bodyLines = ( "--$boundary", "Content-Disposition: form-data; name=`"file`"; filename=`"[file-name].xml`"", "Content-Type: application/octet-stream$LF", $fileEnc, "--$boundary--$LF" ) -join $LF Invoke-RestMethod -Uri $uri -Method Post -ContentType "multipart/form-data; boundary=`"$boundary`"" -Body $bodyLines -Credential $credential -WebSession $session
Download Documentation here:
Import-Export-DM-Powershell.pdf (57.6 KB)
Additional Resources:
cmdlet-format.zip (1.3 KB)
