This recipe demonstrates how to use data cache in the report template.
- Create a report template using the given datasources:
- FruitSales.ds
- FruitSales.ds
- cmps-FruitSales.dsAdd the parameter below into the “Parameters” page:Name=Company, Value=${Company}, Enabled=True.
- Add the following Data Fields (Literal) under “Section Header”:
- From Cache
- From Cache2
- From Cache3 (ds with parameter)
- From DataField: Fruit
- Add the following Data Fields (Script) under “Detail”:
- //total_record;
cache.getObject(total_record, “Fruit”); - //total_record;
cache2.getObject(total_record, “Fruit”); - /total_record;
cache3.getString(“Fruit”); - Select the “Fruit” field in the Data Field (Field).
Screenshot when the user enters “A” for the Company parameter:
HowToUseDataCache.zip (4.6 KB)
