This recipe shows how to tokenize columns using JavaScript in a composite datasource.
- Create a composite datasource (cmps-Concat.ds). Drag and drop the tabular datasource (Concat.ds) as the beginning of the flow.
- Add a “Derivative” element following the tabular datasource. In “Derivative > Derived” tab, add the following columns:(Column1) Name=dev1, Type=String, Value=Col1 + tokens[1];
(Column2) Name=dev2, Type=String, Value=Col1 + tokens[2];
(Column3) Name=dev3, Type=String, Value=Col1 + tokens[3]; - In “Derivative > JavaScript” tab, enter the following code:importScript("/Elixir/ER_Cookbook/lib/Tokenizer.js")
var tokens = Col2.tokenize(",", “”, false);
HowToTokenizeColumn.zip
