Known Issues and Patches in ERS 7.1
- Render Report Template with Parameters to Target via ERSClient
Problem Description:
Rendering a report template contain parameters via the ERSClient API to a configured Target failed with the error message below.
Error Message:
2007-09-03 12:58:27,000,btpool0-5 - /target/output1,ERROR, object.ObjectDataSource - JavaScript error: Execute error
org.mozilla.javascript.EvaluatorException: Compilation produced 2 syntax errors. : line 1 : null
Execute error
at com.elixirtech.js.JavaScriptEngine.execute(Unknown Source)
at com.elixirtech.data2.datasource.object.ObjectDataSource.pushTo(Unknown Source)
Patch Resolution:
To resolve this, please following the instruction carefully.
- Stop your ERS Server ( if it’s currently running )
- Download patch-7.1.0-02.jar ( DO NOT change the name of this jar file )
- Drop this jar into the 7.1.0 server /lib directory ( DO NOT drop this jar in the /ext folder )
- Start your ERS Server
- MediaSize is overriding the MediaTray
The printer tray that was specified doesn’t get used.
Problem Addressed:
If OrientationRequired is already specified, then don’t override it
If MediaTray is already specified then don’t set MediaSize
Patch Resolution:
- Download patch-7.1.0-01.jar( DO NOT change the name of this jar file )
- Drop this jar into the 7.1.0 Server /lib directory ( DO NOT drop this jar in the /ext folder )
Note: This patch can be used for both ERS Designer and Server.
patch-7.1.0-01.jar.zip (3.0 KB)
patch-7.1.0-02.jar.zip (3.6 KB)
