This recipe demonstrates the use of FileLoop task of a job in the Schedule Designer.
- Create a job file (FileLoop.job). Add a FileLoop task under the FileLoop.job on the “Design” tab. Fill in the following information for the FileLoop task:Name=Loop-ER_Exercises
Enabled=true
Folder=ElixirSamples
Recursive=true
Parameter Name=FileNameAdd the following File Criteria:Test=Extension, When=Equals, Value=rml - Add an Echo task under the FileLoop task. Fill in the following information for the Echo task:Enabled=true, Echo=Detected ${FileName}
- Run the job. You can view the output on the “Logs” tab.
FileLoop.zip (3.7 KB)
