This recipe demonstrates how to work on the Ant task of a job in the Schedule Designer.
To allow this to work, you have to create two folders, if you are using a Windows operating system:
- C:/tmp
- C:/tmp2
Once this job is run, you will notice a copy of tmp is created in ‘C:/tmp2’, Example: C:/tmp2/tmp
- Create a job file (Ant.job). Add the following parameters:Name=From, Value=C:\tmp, Enabled=true
Name=To, Value=C:\tmp2, Enabled=true - Add an “Ant” task under the Ant.job on the “Design” tab. Enter the file path of build.xml. Add the following parameters:Name=ANT_FROM, Value=${From}, Enabled=true
Name=ANT_TO, Value=${To}, Enabled=trueSet “Build Target” to build. - Add an “Echo” task under the Ant.job on the “Design” tab. Enter the following into the “Echo” field:########################
Copying from ${ANT_FROM} to ${ANT_TO}
Ant.zip (174.7 KB)
