To filter Singapore’s NRIC format, one can make use of the filter processor.
Use a JavaScript Filter and enter this format/^S[0-9]{7}[A-Z]{1}$/g.test(NRIC) where NRIC is the fieldname to test.
New format of NRIC uses the character “T” to start and can be detected using /^T[0-9]{7}[A-Z]{1}$/g.test(NRIC).
- Create a composite datasource (+.ds). Drag and drop the tabular datasource (Data.ds) as the beginning of the flow.
- Add a “Filter” element following the tabular datasource. In Filter #1, add the following column:Name=NRIC, Type=String, When=JavaScript, Condition=/^S[0-9]{7}[A-Z]{1}$/g.test(NRIC)
- In Filter #2, add the following column:Name=NRIC, Type=String, When=JavaScript, Condition=/^T[0-9]{7}[A-Z]{1}$/g.test(NRIC)
Upon rendering, only strings that meet the NRIC format condition will display.
Filter-NRIC.zip
