This recipe demonstrates how a filter can be carried out on a timestamp. A composite datasource has been created to derive an “Hour” and “Minute” column to hold the values.
A filter is then carried out using the filter processor using either straightforward drop-down commands or simple Javascript for more precise filtering.
- Create a composite datasource (cmps-FilterByTime.ds). Drag and drop the tabular datasource (Employee.ds) as the beginning of the flow.
- Add a “Derivative” element following the tabular datasource. Make the following settings:“Derivative > Base” tab: Discard the column “end_date”.“Derivative > Derived” tab: Add the following two columns:
Column 1 – Name=Hours, Type=Integer, Value=hire_date.getHours()
Column 2 – Name=Minutes, Type=Integer, Value=hire_date.getMinutes() - Add a “Filter” element following the “Derivative” element. Make the following settings:Column Name=Hours, Type=Integer, When=JavaScript, Condition=Hours >=10
Column Name=Minutes, Type=Integer, When=More Than, Condition=20
FilterByTime.zip
