[FAQ]: Create a Filesystem
Steps to create a Filesystem are as follows:
1/ Accessing http://localhost:8080/elx/index.html in a web browser
2/ Fill in ’ Domain name ’ as ’ eno ’ (default) ==> Go
3/ Click on ’ Manage this domain ’ on the top right corner
4/ Enter default username as ’ domadmin ’ and password as ’ da ’
5/ Click on ’ Repository ’ tab ==> ’ Add File Store ’
6/ Fill in Name, Description and Path, see example below:
  • Name: Template
  • Description: Storing report templates and datasources
  • Path: ./data/dacapo/eno/repository
7/ Next step would be ’ Add File System ’
8/ Fill in Name of the filesystem, choose Store that you just created (Store can be reused for many Filesystems) and tick on ’ Searchable ’ if needed
9/ Start the Designer, you should be able to see the created Filesystem not under /user folder
